Hi There,
For Syntess Software (Holland) i'm trying to install Firebird 3.0.4 on CentOS 7.7.
- When i use this package: https://copr.fedorainfracloud.org/coprs ... /firebird/ i get an error while connecting to firebird that te installation is not completed.
- When i build from tar.gz file the gbak/gfix doesn't work.
Both times the installation seems to be working / going well.
Both times i can see firebird running as a proces/service.
Does someone over here have some experience to share with me, or point me in the right direction?
Thanks in advance
Arjan
Syntess Software
Contos 7.7 firebird 3.0.4
Hi Arjan,
since this is a German forum you won't get useful feedback I think. But usually your described problem indicates that there are problems with the user authentication. Check your usernames and Plugins.
Try to use this options in firebird.conf
Good luck
AuthServer = Legacy_Auth, Srp
UserManager = Legacy_UserManager, SrpMartin
