Contos 7.7 firebird 3.0.4
Arjan-Syntess
Hi There,
For Syntess Software (Holland) i'm trying to install Firebird 3.0.4 on CentOS 7.7.
- When i use this package: https://copr.fedorainfracloud.org/coprs ... /firebird/ i get an error while connecting to firebird that te installation is not completed.
- When i build from tar.gz file the gbak/gfix doesn't work.
Both times the installation seems to be working / going well.
Both times i can see firebird running as a proces/service.
Does someone over here have some experience to share with me, or point me in the right direction?
Thanks in advance
Arjan
Syntess Software
Hi Arjan,
since this is a German forum you won't get useful feedback I think. But usually your described problem indicates that there are problems with the user authentication. Check your usernames and Plugins.
Try to use this options in firebird.conf
AuthServer = Legacy_Auth, Srp
UserManager = Legacy_UserManager, Srp
Good luck
