Hi, Martin!
Thank you for your work!
Just try to test your module, but unfortunately apache error log shows:
PHP Startup: interbase: Unable to initialize module\nModule compiled with module API=20151012\nPHP compiled with module API=20180731\nThese options need to match\n in Unknown on line 0
interbase7.3.so Ubuntu 19.04
Hallo Valentino,
danke für dein Feedback. Ich werde dies überprüfen.
Hi Valentino,
thanks for your feedback. I will check this.
Regards
Hi Valentino,
Regards
Ja, du hast recht. Mit der angehängten Version sollte es nun gehen. Ich werde diese auf die Firebird-Homepage hochladen.
Well, you're right. The attached version should work. I will upload the file to the Firebird homepage as well.
Regards,
Regards,
- interbase.tar.gz
- (120.85 KiB) 1152-mal heruntergeladen
Thank you!
It's already works!
It's already works!
